terex herder
Good deere dealers will have a large assortment of individual deutsch components.
The tools need care because they are easy to snap. What holds the pin/socket into the connector are two plastic “fingers” inside each hole location in the connector that lock on the flange that is located right below the wire crimp so that the wire can’t be pulled out. If the tool doesn’t engage the fingers the first time, pull it out, rotate it 90 degrees and slide it in again. Patience is key.
For operation of lift axle remove any of the old Parker/Norgren and install a GT5040-311 full function valve.
It's the simplest easiest way to go. Very little trouble with them, only replaced one in 5 years.
Cross reference numbers in link.
Hey Crane Operator,
First time posting here, I stumbled across this forum a few weeks ago and have been reading through years of old post ever since. My question for you is how bad is pulling the swivel? I have a tms300 that's leaking air into my hydraulic tank. I'm half tempted to just run an air line up through the center with its own little swivel and cap the ports through the main swivel, as we have an old pettibone and a manitex boomtruck that is done this way. But the wires coming out of the top look like a nightmare and I'm slightly afraid of disturbing them, plus for the life of me I cant seem to find one of the air swivels in all my google searches.
Another question for you as I see you have a tms500e, I know the counterweights aren't hydraulically removeable but are they modular in a way that you can remove the heavy counterweight package relatively easily with another crane/lift? I'm always looking at used cranes to try upgrade ours and would like to not have to get overweight permits. I've always thought I would probably replace the tms300 with a tms540 with the 90' main. Its one of the few 40 ton cranes with hydraulic removeable counterweights and it has pretty good jib chart for the construction work we do. But the other day I was reading the spec/load chart brochure on the tms500e and I see they talk about different counter weight set ups but they don't really say if the configuration can be changed after it comes from factory. I just see you have one so I thought you could give some insight on the counterweight set up. Thanks
