Just bought a Deere 333E
tool_king
new jersey
road mechanic owner
Can't get into those manuals anymore. I'm getting a active ECU
code 2950.05 , Suction Air Throttle Actuator , out of range low. Any suggestions? I also finally got my forks, ordered a 6' wide Jenkins Steel with 5' forks rated at 5,500#. I wanted wide to see if I could get by with these instead of getting a grapple. Unloaded yesterday and seemed to work well with forks spread about 5' apart. Only got to play with them for about 30 minutes last night. Only issue was it took a month and a half to finally get them. I want to order the 84" Jenkins Brush grapple (not sure why they call it a brush grapple when it looks like everyone else's root grapples). But if I can get by with these forks moving brush, then I can spend the money on other equipment needs.
Do you need another copy of the manuals to download them?
terex herder
Kansas
Before you buy a grapple, look at the Faver grapple. The tines are AR400 and don't have tie bars across the front. I've worked mine plenty hard in concrete as well as trees/brush, and haven't bent a tine yet.
hmearth
Australia.
Ray450 if you change you hyd oil out to 10w68 your JD will work better i did mine about a 100 hrs and it was like i had a new machine
ianjoub
Homosassa, FL USA
I have 2 attachments from https://skidpro.com/ They are both VERY WELL constructed. I have a high flow forestry mulcher and an 84" rock grapple.
I just sold a rock grapple from another mfg. that was a POS. Skid pro was more than twice the money, but well worth it.
Ask for Dick in sales.
I have no affiliation, just a happy customer.
Joe Fick
I used to own a 333E n now have a 333G if you have any questions etc holler. I run alot of John deere tractors n ctls
Ray450
GreenvilleTexas
Police Officer and offroad race promoter
Finally bought a gooseneck and can haul this thing. It's been throwing a code since I've owned it, "2950.05 , Suction Air Throttle Actuator , out of range low", I have not been able to find any info on what to do to fix it. Accelerator pedal also seems to be not working well, I usually just set the throttle with the knob. I called two local dealers, both said they would get back to me about that code and never did. This thing goes thru a lot of hydraulic fluid and I can't seem to track the leaks, although I know where the oil is leaking, drain bolt connection to the outside port. Anyway, I plan on taking it to a dealer. I'm between three dealers, Terrell, Sulphur Springs and Mckinney Tx. The one in Terrell is small and is listed for just Ag equipment, but they said they service the yellow Deeres as well. Never been to Sulphur Springs, probably 10 mins further, also does not sell yellow. The one in Mckinney is by far the biggest and deals with yellow and green Deeres, but is probably 30-45mins further away. Any recommendations?
mg2361
Pennsylvania
Equipment Mechanic
Maybe this will help.
  • 333E 2950.05 Diag.pdf
  • 333E Air Throttle Schematic.pdf
  • E-Series and G-Series Factory Fill Fluids.pdf
Ray450
GreenvilleTexas
Thanks, I'll play around with that and see if I can figure it out. There is a huge amount of dirt in the bottom of the engine/pump compartment. I've scraped out several buckets of dirt, and many hoses/components are buried, making finding leaks very difficult. I've been hesitant to remove all the covers on the bottom and clean it out with a pressure washer. Good or bad Idea? Obviously I'd try to avoid getting close to electrical components.
Joe Fick
ive power washed mine it didnt hurt anything i had dropped all the belly pan pieces n got to washing i think i spent 2 hours cleaning mine out at 500 hours but it had alot of leaves in it scince i do alot of land clearing and extreme dusty enviroment
mg2361
Pennsylvania
Equipment Mechanic
Joe's right. Power washing won't hurt it. Just don't spray the controllers on the side. There are small steel lines on the bottom and being buried in dirt, especially damp dirt, they like to rust then leak.
JNB
North Texas
Flyin' low and rollin' slow...
I've never had good luck with ag dealers that also service the construction side. It's a bit of a drive for you, but I'd give RDO a call. Everything Deere Const, I see around here has one of their logos on it.
Ray450
GreenvilleTexas
Managed to find one of the problems, a broken wire on the Air throttle. Looks like the cab strut hit the harness connector and took out a wire, and scrubbed up another. Will have to solder later, but was able to connect it and was not getting the code anymore. It also almost immediately went into a cycle for the emissions, even though it's showing "low soot". It was staying at 1800 rpm, and I think I had read somewhere you shouldn't shut down if it starts, but I had to pick up a kid at daycare, so I had to shut it down after giving it 20 minutes. Never found the hydraulic leak, but got most of the dirt out of the bottom and put in a new battery. I need to spray it out good later, but was running out of time and it was cold. Might not have to take it in now, but funny you said that about RDO, because mine has a big RDO sticker on it as well. None of the Deere dealers ever did get back with me.
warpspeed
United States
Oil leaks are nature of the beast unless its streaming out. Oil is cheap. Keeps the frame from rusting.
Get familiar and registered with jdparts.com and call your orders in or Google part numbers for online deals.
My jd service manager won't tell me how to diagnose anything just pay him $125/hr service calls so I don't go out of my way to support them on parts.
Try not to buy a attachment from oem dealer too much markup. Do some digging online and find your closest quality aftermarket attachment mfg. Co.
Here it is aim or werkbrau or tag
I've beat the tar out of a aim grapple, still works fine.
https://aimattachments.com/?gclid=C...c3EHXua-VTir4dEaOcUVurY7rVyE0ZMxoClpAQAvD_BwE
dwreck
Hi all,
Not to butt in but this looked like a good place to start. We just got a 2014 jd 333e with 2800 hrs, we put up a home and now need to clear some acreage. quick question is there any place to get operating and service manuals as mine didn't come with anything and this is my first run with a CLT, theres a lot of buttons and switches on these things. Any help is appreciated.
dwreck
I haven't seen anything yet on ebay, I was hoping there was alternative to going to dealer. How about place to get parts (online)? Any recomondations?
tool_king
new jersey
road mechanic owner
Hi all,
What is your email address? I can email you the manuals .
