John Deere Loader help!!
JakeDearing
Port Arthur Texas
I've got an older model John Deere loader that I believe to be a 544 model. However, my serial number has been painted over. I've tried everything I can to get the paint off of the numbers but the solvent is cleaning away the numbers as well. I do however, have the cab enclosure serial number and am wondering if anyone knows a way to identify the machine by the cab enclosure number
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
If it has a Stanadyne injection pump on it, they are real good about giving the engine & application on their pump specs..
SO, if you can give me the #'s of the injection pump, I might be able to tell you whatcha got..
thepumpguysc
The engine is a> 6059TT001
Application is> 710C, 544G, Loader/710D, Backhoe/TDW02..
Sorry but there are several to choose from.. I hope it helps some..
I don't know how to come up with the machine serial number. But when you get to the point where you have a part that has a serial number break, you can usually tell easily enough which one you have with the part off, so you should be able to narrow it down to a range if/when that matters.
