John Deere 319D aux hydraulics not working
Firescooby
Georgia
2013/14 with around 2200 hours.
Machine is a hand/foot control machine.
I bought this machine used, never used aux hydraulics before on it. Borrowed a trencher and they will not work.
I've got the following codes:
AUX HYD EXTEND OUTPUT OUT OF RANGE LOW
AUX HYD EXTEND OUTPUT OUT OF RANGE HIGH
AUX HYD RETRACT OUTPUT OUT OF RANGE LOW
ENGINE OIL PRESSURE OUT OF RANGE HIGH
FUEL PRESSURE SENSOR OUT OF RANGE LOW
I replaced the right joy stick and included harness with no change. Still have the same codes.
Any info or help?
mg2361
Pennsylvania
Equipment Mechanic
Post the serial number please. Also be specific with code numbers. Descriptions do not really help.
Barry2478
Harmony
Need help I tried going into service menu on my 323d it doesn't say anything for joystick or roller, to test for aux hydraulic not working. Mechanical machine
Barry2478
Harmony
I found aux extend/retract with key on engine off they both read 0 Amp with roller in any position
mg2361
Pennsylvania
Equipment Mechanic
Welcome to HEF Barry,
Need a complete machine serial number so accurate information can be accessed.
What codes do you have (active and stored). Post them by the numbers, not by description.
When checking the amps, were in the seat, seat bar down, if a cab machine, cab door closed?
