hosspuller
Farmtoys … TPG is being bashful. While the debris "Could be" dirt or rust... consider the very fine fuel filtering set up Deere designed. Ask yourself how could dirt get through it, to get into the pump. Very likely, the debris is coming from the pump itself. So something in the pump is coming apart. This particular pump design has a flexible ring that holds the governor weights. It's well known for the flex ring to break down and shed pieces.
In my case the only decision was to go back to the flex ring or a more expensive part that eliminated the break down and the flex ring. I chose to stay with the flex ring since it took 30 years to fail. I figure it'll be someone else's problem in another 30 years.
