john deere 310c backhoe Transmission and Hydraulic Oil.
flyingpassage
Waldoboro Maine
retired UPS feeder driver
I have a 310a which is a little older then your 310c but mine the oil is shared, there is a transmission pump in the transmission that pumps oil to the pump up front,I am sure yours would be the same set up. When it gets warmer I am getting ready to change the oil out. I have Rotalla hd oil for it which is 10w 30w fluid
mg2361
Pennsylvania
Equipment Mechanic
Dose the john deere 310c backhoe Transmission and Hydraulic Oil share the same Oil?
Welcome to HEF Keneth;)! No, they are separate reservoirs. Same oil, yes. Hydraulics, transaxle and the reverser use Hygard.
geminijo
minnesota
Transaxle has a dip stick/fill tube under a flap in the floor mat in front of the seat under your left leg when seated while driving.Reverser dip stick /fill tube is behind swing out door right above the hydraulic reservoir on the right side( while seated) of the hoe
mg2361
Pennsylvania
Equipment Mechanic
Reverser oil is checked with the transaxle and reverser in neutral, park brake engaged and the engine idling. The transaxle oil level is checked with the engine off.
