That's good, it means the pump isn't locked up completely.
I'd replace the fuel filters if you don't know when they were replaced last. Take apart any fitting between the tank and the transfer pump to check for garbage. Or blow back to the tank from the transfer pump. Do whatever it takes to get the fuel flowing better. Then loosen a couple of injector lines at the injector, carefully to not bend the injector, use two wrenches. Then hook the supply back to the injection pump and crank for ten seconds at a time, with five minutes rest, until you get fuel out the injector lines with no bubbles, then tighten them and it should start.
