John deere 225dlc boom wont go down
mg2361
Pennsylvania
Equipment Mechanic
Where do I start
With a machine serial number please.
Unless you have the controlled lowering device option, then I would be starting with the boom reduced leakage valve. I would remove the poppet and run the machine. If the issue went away, then either the poppet was sticking, or the poppet's pilot control spool is sticking.
NOTE: make darn sure the boom is on the ground and all pressure is relieved out of the boom circuit before removing that poppet cover or poppet.
