John Deere 219 engine: trouble starting after rebuild
pjflyer
Wolverine, MI
We don't have the tool, I think it's JD 234 or something, but looking at the pictures it lines up with the center of the crank. So we took a straight edge and went center of crank to center of shaft of whatever is being timed and put the timing mark along that line. The tool looks like a Y.
That brings up a question we had about the balancers. The book said to mark them left or right before you take them out, but no way to id them otherwise. We got the engine dismantled and they weren't marked left or right. Both of them have the same numbers and no left or right designation. They have the timing marks on the gear. They can go one of two ways. If the timing marks are aligned with the crank, does it matter which way they go?? Or is it that as long as they are spinning counter opposed the important part??
rondig
fort macleod alberta
excavation
Yeah the higher rpm sounds like motor was too tight causing governor to stroke pump....caps going on backwards is not right at all...did you lube liner seals before putting them in? Do not use oil as they will swell. Also i use bearing floss...looks like dental floss...it measure bearing clearance when torqued. Also if caps didnt fit...sounds like line bore was not done...i would always line bore on an unknown engine.
mg2361
Pennsylvania
Equipment Mechanic
With #1 piston top dead center on compression the weights should be straight down. There used to be an "L" or "R" stamped on the back of the balancer behind the last journal. They are different art numbers.
pjflyer
Wolverine, MI
We didn't use any lube on the liners just slid them in. Good to know about the balancers, I'll check again for l or r, but the straight down part we can make sure of. And then mark them!!
  • Like
Reactions: DB2
pjflyer
Wolverine, MI
Ok....Who's the winner? After pulling the engine and pulling off the oil pan, it was obvious it was the last bearing causing the issue. The crank was pushed forward and whatever the piece that the flywheel bolts to is called, was rubbing on the thrust portion of the back bearing (#5). We didn't get the crank pulled out yet, but with #5 bearing cap removed, the crank spun fine. I'm not sure what how bad the damage is to anything, but so far it seems contained to the bearing. Here are pics of the oil pan with shavings, #5 cap, and the crank still in the block. We were able to tap the crank forward. When we first pulled it apart, the bearing and back of the crank were touching.
We think we probably bumped the crank on the spline while putting the engine in. We don't recall it bumping or it hitting hard, but with the weight of the engine, it probably doesn't take much to move it (the crank). Which brings up the question of if we did bump it, would it stay there or work away from where it's touching and binding? Or what else would've caused it? DSCN1357.JPG
pjflyer
Wolverine, MI
More pics.
BigWrench55
Somewhere
Could you load pictures of the rest of the main caps? It looks to me that you have one swapped. The picture of the block side shows a thrust bearing and the main cap picture doesn't have a thrust bearing in it. Either the bearing is in the wrong place on the block or the wrong main cap is installed. 20190125_230704.jpg 20190125_231031.jpg 20190125_230704.jpg
pjflyer
Wolverine, MI
Now that you mention it, I know what you mean. I'll get more pics tomorrow as we get it apart. I will also try to pics of how the caps line up with the block. Looking at these pics I'm getting myself confused!!
farmerlund
North Dakota
Farmer/ excavator
I agree with Paul. The thrust bearing should go all the way around, not just 180 degrees. plus thrust main caps are different then the rest. You must have the other half of thrust bearing in the wrong location also. lucky it didn't run long.:eek:
mg2361
Pennsylvania
Equipment Mechanic
Take note that when you have the proper caps in the proper place and you install the thrust bearing and it's cap Deere's procedure says to install thrust cap hand tight then tap crank towards the rear (use a dead blow, not a steel hammer), then tap crank towards the front then tighten the bearing cap (see highlighted text in attachment). Then check your end play. It should be 0.002" - 0.015". Make sure when you install engine you still have crank end play and that something external is not "pushing" the crank front. Also if you would please, post a picture of the number side of the main caps.
  • 440A Thrust bearing.pdf
pjflyer
Wolverine, MI
I see in the picture it's hard to see the flange on the outer part of the cap. I will get more pics up later today. We also did tap the crank both directions to set the thrust bearing before we torqued the caps, that's why we were thinking something moved the crank forward either during or after the install. It's hard to see the stamped numbers on the caps, but I'll try to get at an angle where it shows up. These were the caps that came with this block and engine. I see what a nightmare it is getting an engine that has already been torn down.
56wrench
alberta
in the picture of the #5 main journal, the fillet radius of the crank does not appear to match the bearing. so either the thrust bearing is in another location, the crank is not properly reground or the crank is wrong for that block. were all the upper bearing shells installed with the oil holes lined up properly? usually, the lower shells don't have oil holes in them
pjflyer
Wolverine, MI
I now have a question as far as matching up the stamped numbers. Are they supposed to line up if the engine was split in half left to right or front to back. If it's front to back the numbers align.
All of the bearings had oil holes in them. I'm attaching several pics.
Here is the order of pics:
Number on cap #1
Numbers are at my finger tip and tip of thumb which are hard to see. I couldn't get at any better angle.
In order #1 through #5
#5 bearing outside of block - 2 pics
#5 bearing inside of block
next 4 are of the caps with bearings in without the crank. I see #2 wasn't all the way down, but it does go.
#5 bearing slot without the bearing outside the block
#5 bearing slot without the bearing inside the block
#5 thrust bearing removed.
pjflyer
Wolverine, MI
more pics
