Aloha ,
I have a 410B with leaking out riggers ( STABILIZERS ) I got the nut off but cannot see the metal clip or ring . So I understand that you have to knock the threaded part into the cylinder to get to the ring , then remove the ring to get the gland etc out .
Well , I have not had any luck getting this part to push in . I am sure you guys have some experience in this . I need some guidance . I was going to remove the complete cylinder and take to a hydraulic shop but the top pin will not come out with heat , etc. so removing the complete cylinder is not an option unless I carbon arc (gouge ) it out .
I have repacked cylinders before and am familiar . So can you experienced guys give me any insight ?
