I really don't know why this happen. It was nothing wrong with this engine. The tractor was always run pretty good , what happen is that I have other tractors so this one we hardly used and it was left for about 2 years in the field and when we went to started up the engine was lock and had a lot of water in it. I took the engine apart and got it free, so we went ahead to do an inframe rebuild , we keep the same pistons we got new bearing ,pistons rings, now new lifters and pushrods, new fuel lift pump and rebuild the injection pump. the only thing that I didn't do was to remove the camshaft and check the bearings. Unless something is wrong with the bearings or the camshaft I really don't know what else can be bending some of the pushrods not all of then this is happening to. Thanks for all the help and I will post by this weekend as soon that i pull out the camshaft , I'm hopping that something is wrong.
