headwrench
- Joined
- Feb 29, 2008
- Messages
- 31
- Location
- ellington connecticut
- Occupation
- mechanic for agriscape golf course construction
Have Had A Battery Draw Problem With Machine Since Day One. Deere Thought They Fixed It Twice, No Such Luck. Have Cleaned All Grounds,charging System Is Fine,problem Is Somewhat Intermitent.have Pulled Fuses To Check For Draws No Luck. Once Had Hooked Jumper Cables To Machine Main Ground Caused An Arc And Power Came Back. Thought It Was Abad Ground Cleaned All Grounds Two Days Later Same Problem. Considering Alternator Draw? Appreciate Any Input.or The Possibility Of A Bad Battery Shut Off Switch.
