JCB 214 Transmission issues
Ktricky
Sacramento, California USA
I posted a thread earlier and I'm still having issues. 2004 JCB 214. Unit runs great. Forward and reverse run fine for 10-15 min. Then it stops moving forward or reverse. I'm losing pressure when it stops moving. I've already changed out the pump. Then the pressure release valve. What else could it be? I'm lost and dumping money into this thing.
Previous post: https://www.heavyequipmentforums.co...khoe-transmission-issues.102279/#post-1156815
Timothy Young
Michigan
Semi-retired
Did you ever find a solution? I having the same issue on my 1999 - 214S. I presume you discovered a fuse was blowing, but the solution I suspect is one of the shifting solenoids. Would love to know what you discovered.
LN Pipeline
Montana, USA
If I remember correctly, he posted again and the remedy to his problem was cleaning the strainer for the transmission oil.
