I want to learn a little more about tractors before I buy one, help please.
ttazzman
missouri
20hrs???......you need to choose a much higher gear range......i once mowed (bush hogged) 10 acres with a small (40hp) john deere tractor with a 6' rotary cutter and even with thick high brush/grass/weeds to mow it only took 4 hrs...i assume your mowing with a MX6?
for what its worth.....when i "mow" i pretty much run at the same ground speed all the time which is usually a speed i have determined to be the fastest i can go at PTO speed and it still make a clean cut ......if the grass is thick i dont change speed or raise the mower i just take less than full cutter width to take load off the tractor this also lets the cutter clear debris easier........i dont own a hydrostatic tractor so i am not sure exactly how you set your speed etc with one so things might be different.....
fishfighter
Louisiana
Thanks fellas! So true, I do want a larger tractor already. It took 20 hours to mow my place, too long.
Thanks again for the help!
You need to learn how to run it. LOL I have a old Ford 2000 that I clip with a 6' cutter and cut more then 20 ac in 12 hours. Best thing is that I only burn around 10 gallons of diesel in that time. I only cut that twice a year.
