Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
I have one that started doing that 7 yrs ago, get the motor warmed up and put 4-6 cans of Conklin Dike in the radiator. I was surprised on good it worked, we are still using the truck with no leakage.
Sounds serious to me, maybe a head gasket or the bolts are loose if its weeping out by the gasket, I'd pull the head off and have it checked out to see if its warped and or cracked and if the gasket's bad, is it leaking water into the engine as well, do you get water in the oil or just leaking on the ground?
Randy 88 is right. leaking head gaskets was a problem on them. Bolts would stretch and or brake. you don't need an overhaul probably just head gaskets and new head bolts and you'll be good for years.
I have seen high mileage Cummins leaking oil and water.The heads would vibrate causing the liners to wear are crack the ridge.Have seen where the block had to be resurfaced too.But these engines will run a long time doing this.Easier to do during out of frame over haul.
jsut depends on what the block surface looks like Cummins offewr oversized headgaskets but u really need to pull it down and check block surface no sence in spending good money for a temp fix ( band aid on a cut that needs sewien up) done been that route $2000.00 for head gasket with no garanty or 12 500 for Cummins Recon engine with 2 yr warranty ended up total out the door price of $21,000 for the repair but got a good motor that now has about 200,000 on and only repair so far is STC valve and water pump
