BillG
Does anyone know of a test port kit that has the most common quick connect fittings. Also as long as I started this, what is the most common fitting that you find like the Parker PD or whatever.
You said that right ...seems like I probably have 50 lbs. of fittings on the truck lol...And then theres O rings lawd ..Just when i think i have all the fittings i need then i go to work on our dooson and its some sort of british fittings. As Atcoequip said off to the local hyd shop.
