Eddiebackblade
I have a problem with my zaxis 160lc, the operator reported that it had 'clicked' twice on the starter before starting as normal.
It has continued to start normally with no problems, until he noticed two warning lights sticking on when the ignition is turned off.
The warning lights are oil and battery and give the impression the ignition is on, however upon turning the key the relays can be heard and the full set of warning lights operate along with the radio etc.
Upon investigating the only way to turn them off apart from disconecting the battery is remove the fuse marked 'sw box'.
I assume this is 'switch box' but cannot see the relavance to the illuminated lights.
If I remove the battery lead there is a fair spark indicating that something is definately pulling current.
Apart from the hassle of disconnecting the battery each night, everything else electrical works perfectly.
I have ordered a new ignition switch as it needed replacing anyway, and will fit a heavy duty battery isolator switch with removeable key in place of the sometimes problematic automatic Hitachi item.(good for security anyway)
Just wondered if anyone has experienced similar or has any ideas.
