Hitachi ex120-5 won’t turn off with key
maineplower
maine
I have a ex120-5 that I bought with the throttle control missing. I put a new motor and cable on both Deere. I’ve set the idle rpm’s with the computer and done the learning procedure. I tried a different key switch. Still it won’t turn off with the key. Any ideas??
mg2361
Pennsylvania
Equipment Mechanic
I think that machine is the same as a Deere 120. If so, sounds like the V2 alternator shut down relay isolation diode is shorted. The diodes are behind the seat, below the fuse box. To identify the diode in question, it should have a red/white and red/black wire going to it.
mg2361
Pennsylvania
Equipment Mechanic
Yep. On the Deere "LC" series they called it the shut down relay, starting with the Deere "CLC" series they called it the load dump relay.
maineplower
maine
I changed the relay no change. Could it be something to do with the alternator back feeding the machine after the key is off? The key shuts everything off like the heater fan etc properly when the engine isn’t running, as soon as engine is running key doesn’t shut things down.
maineplower
maine
Found them. Swapped it with another and it works. Have to get another Monday from the dealer. Thanks for your help
maineplower
maine
This worked fine for a few works, now won’t shut off with key again. What would cause the diode to fail?
mg2361
Pennsylvania
Equipment Mechanic
No. An intermittent dead short of the wiring to ground "after" the diode is more likely the issue.
