Help with Cat 955k serial number
Birmingham
Hey Jon,
Thank you so much for the info sir. With Nige’s help I found a used cylinder barrel with Off-road Equipment in Alcoa, TN. I’m going to order it Monday and continue trying to get the machine ready to work. Thanks so much again for your time Jon.
Birmingham
We got the machine up and running, and I’ve done a little work with it. Seems to be running well so far. I’m starting to get the hang of the controls. Can y’all help me with what this wire is on the top of the engine? It is broken, and I can’t find what it goes to in the manual.
The photos are not very clear, and neither is the service information I can find. All they show is a wire somewhere close to the exhaust manifold.
Can you trace where the wire goes, or what colour it is, anything that might help identify what it is.?
Could it be part of the wiring for the glow plugs.? Do they work.?
Attached is what's listed for wiring but I don't think it's going to help you much. The electrical schematics won't load up for some reason.
  • 6K5389 Battery & Wiring.pdf
  • 6K5950 Engine Wiring.pdf
OzDozer
Perth, Western Australia.
Semi-Retired ..
That looks like a wire going to the glow plug, to me. If the wire is broken, that particular glow plug won't heat up when you hit "Heat" on the Start switch, but all the rest of the glow plugs will still work.
sawmilleng
Central Kootenays, Canada
A thought to try: Oz's suggestion that it could be for a glow plug could be checked by getting a multi meter and checking for power in the wire (with the other meter lead clipped to ground--somewhere on the engine block)
Once this is set up, try turning on the glow plugs and see if you get power in the wire. If so, it is probably a glow plug wire. If not, well, you have eliminated one possibility.
It seems to me that glow plugs are generally hooked up "daisy chain" style so I'm not so hopeful that this wire is for them.
Jon.
Birmingham
Hey Nige,
The 955k is up and running, and I have been able to get some work done with it. Thank you so much for the help so far. Can you answer a question for me sir? Can you please look at the pictures I’ve attached? What is the crow bar looking thing in the picture? This compartment on the other side of the machine is bolted down flush.
OzDozer
Semi-Retired ..
Looks to me like the biggest hick, on-the-fly repair, that you could ever find. Jam a wrecking bar in under the track guard, and wire the access flap to it, to stop the access flap flopping around - instead of just welding a new nut to the guard, and installing a new bolt to hold the flap closed.
