I know you werent considering a mack, but this granite is in clifton park. Already has the permit, and a third axle could easily be added. Take a look.Not a bad deal!!
www.wantaddigest.com
its under heavy duty trucks.
Add looks like this:
MACK CV7 2004
tandem axle, 1800# f/a, 44000# r/a, 16' steel ox body, 10spd overweight permit, 18T, 83.8kmi,
$69000 B/O Clifton Park, NY
What can you register a truck for in NY state. Total GVW on this truck is 62,000 lbs, assuming the front axle is 18,000 lbs? In NH you can go to 65,000 lbs for a 10 wheeler, and 73,000 lbs for a tri axle.
Plus it has an OX body, so it proably is a southeren truck without body heat.
The pick up truck interior is easy to clean. Doing site work the trucks always get dusty inside.
You would have to get an overeweight permit to lisence it for the full 62K, otherwise the max you could register is for would be like 54K or so, they use the bridge formula to determine it. With a lift axle added I would think it could be lisenced for 70K or so. I think thats a decent truck, and a decent price. I think I might be the only Mack fan on the board!! Plus I found a Mack dealer right near the WS dealer about an hour or so away!
Around here it 55k but with over wieght permit it is 64k. Then with a tri you can hual with over wieght 73k. As for you being only mack lover, not so I think they are a great truck there tough as nails and I also like there look. But from my childhood memories I don't ever remember them being at all comfortble. Also am a huge fan of the autocar.
