rogerellingson
Hello from Portland Ore. I recently purchased 1998 Grove AMZ50, 2WD, Kubota engine 'aerial work platform' HE manlift for a personal building project. The unit is clean, fully functional, and reports 1800 hours of use. Of course, I hate that I currently do not have access to parts or service manuals... Outside of this form (which I have found the best and greatest, thank you!) sounds like Minnpar is the most likely source for Grove support these days.
Problem: Riser hydraulic action is jerky and jumpy.
Solution so far: Check hydraulic system for air/water content, look for clogged screens, change filters regularly.
Help?:
Is this really a problem for the AMZ50? Should the riser action be just as smooth like all other hydraulic operations?
Overview of hydraulic system maintenance and troubleshooting:
Hydraulic Filters: LH4235?
Help?:
- http://grounds-mag.com/well_grounded/2002_hydraulic/
- http://www.afsga.com/Hyd Trouble Shooting Guide.pdf
