Keep in mind "rated" loader capacity is 50% of the full turn static tipping load, or what will just lift the tires when the machine is fully turned. The loader is wheels up in a straight line, so it is AT LEAST double of the rated load plus another 15 to 20% for being straight, not turned. Add to that that the block forks weigh less than the rock bucket the payload is calculated with, and you get another couple of tons.
I would estimate it to be about 25 ton, and the loader never lifted it, only took enough weight off to scoot it along the ground. With all this in mind, 30 to 35 ton would not be out of line. These numbers match up to LoaderMonkey's block weight estimate.
Remember, rated load is what the machine can function safely at repeatedly, with less than a skilled operator at the controls, so as to prevent accidents, as well as make the machine last longer. You can overload with a good operator, but machine life will suffer. That you have to weigh against the cost of a larger machine to do the work. Considering the 988B is at least 20 years old, I would say it has held up OK.
