Machine is a kubota svl90-2
Symptoms
1. Ruined more than 3 dpf
2. Loss of power under load
Long story behind the issue at hand but it had nothing to do with regen problems, the engine was/is over fueling dumping brownish black smoke that was clogging the filters. Things I have done. Yes I have checked the fuel lines elbows etc
1. New turbo
2. Boost sensor
3. New injectors
4. New harness
5. New injector pump
6. New MAF sensor
7. Engine compression test is good
The machine is deleted because dealers were incompetent to figure out the real issue. Now they won’t look at it and I’m in my own. Machine has no codes, starts, idles, and full throttle no problem. As soon as you put a load on the machine she looses power and dumps smoke. I have done everything engine, could this be hydraulic over loading the machine? I’m lost on this and would really like to get a 50k machine back to work on the farm! Any help is appreciated!
Symptoms
1. New turbo
2. Boost sensor
3. New injectors
4. New harness
6. New MAF sensor
