driveshed
Hi Guys
Well to get this going ,I have a Z45/22 Gennie lift Model# Z-45- 003938, It has the LRG423 Deul fuel,
Eng Ser# 06038 L-18RK
Model # LRG4231-6007-B
Model Code# 5C-199_BA
I got this unit from a freind this fall to help finish the shop and when he drop it off it was running but running rough. but when it got hot it would not start untill it cooled down. First thing we replace was the temp sendor at the front of the engine and put a new coil on it , when it was hot there was no spark at the plugs. After doing that still no fire, chang the crank sensor ,new timing belt and it started right up. it run good but when it got hot all it wanted to do was fire up and stop. So I read the manual I have and found out it was not putting out a enough current at #2 termial at the engine lock out module. that curent come from the alternator so replace it. Once I put that on it has not started since. I have only have spark at the # 1 spark plug once in awhile and it looks let it fires three times when it does fire # 1.
This has got looking at the DIS but one guy told that if the DIS goes it goes . If anyone can up please do , this unit has me puzzled.
Thanks
Dave H
Driveshed
Thanks
Dave H
Driveshed
