CraneInnovation
Hello all,
I just removed the carrier cab on my Gradall to help speed up the rebuild process (cab metal work and complete control system rebuild). I noticed that this completely opened up the engine bay. I know engines are typically fairly accessible on big trucks, but the one on my Gradall is obscured by the cab. Specifically, this has given me awesome access to:
The air compressor
The fuel injection pump
The throttle assembly
The head/valves
The hoses
The engine is a cummins 6BT5.9.
The engine runs pretty good right now, but I'm wondering if I should take the opportunity to service and rebuild these items anyway? Most of these tasks would get MUCH harder with the cab reinstalled.
Also, the engine is completely covered in fresh-looking oil. Should I just go ahead and do a head gasket?
Finally....what are your opinions on steam cleaning? Due to power steering and oil leaks, the entire engine and torque converter are totally covered. I assume pressure washing isn't the greatest idea?
Thanks for the input!
The air compressor
The head/valves
The hoses
