Razorsedge2003
Valve cover model# 4029-c
Unit #4A-64651
Unit #4A-64651
Do you know anything about 103 Model Galion Graders? The one I'm looking at has an RD450 EngineThe 503 is a nice machine but it has a few small quirks that I'd like to address. Do not idle in neutral for extended periods, the trans will not oil the upper two shaft bearings. If you notice one wheel isn't pulling, STOP and at least fish out the broken double 60 chain, it will break the other one and destroy the driven sprockets. Don't patch a broken chain, toss it and put in new, these are a weak design that went backwards from the G series 100 pitch chain. If you see a G, grab it for the finals and the 100 pitch sprocket. Where the drop arms are welded to the circle, if they aren't fish plated already where the little stiffener goes between the two at the curve, do it now. This will break and leave you with a bend slider to try and get straight again.
To your question, yeah they exist but are scarce, try Equipment Salvage in Cambridge Oh. Bob may have one there.
I know this is long winded but I've put a lot hours fixing and repowering these machines and want to pass it on. Oh, one more thing, AC D's and DD's use the same transaxle, aside from the engine bolt pattern. Whew!
Sorry but no, mostly 503's and T500's.
Hi repowerguy, I'm helping a buddy longdistance, who's in PA. He just bought a 503, no idea what year...I'm thinking somewhere around 1960-1962, S/N 503-GI-3776. It still has the original IH UB-220, which he removed to freshen up. When he took it out, he found that the bellhousing had been packed full of mouse nests...the grader had been sitting for the better part of over 20 years. It did fire up and was able to move, although the pressure plate is completely frozen, so he wants to order a new one. The problem is, with me being out in Idaho and doing this by phone and email with him, he doesn't know what brand, size or model clutch kit to order. We have the IH UB-200 service and parts manuals, but the clutch kit they show doesn't look like what he has. Who made the 4-spd manual transmissions for Galion? In my research, I've seen Clark mentioned. I just don't want him wasting his money and time ordering a bunch of different clutch kits to see what fits. Is it an 11" clutch? The IH parts manual also lists two options for the bellhousing, S.A.E. 3 and S.A.E 4....the Galion 503 had the S.A.E. 4, correct?
Thanks for all your help, I appreciate it greatly.
-Fred
Diesel Creek
That pressure plate reminded me of the ones in my scout. Rockwell if I can remember right.
If there is a friction company he can take it to they can match it up pretty easily. We have a place in Portland that I use from time to time for stuff like that call Otts Friction.
I’m pretty sure it’s a Rockford, but to be honest we always reused the old one, or use a takeoff from a parts grader. It is a Clark transaxle that’s a SAE 4. BTW, a AC D grader uses the same transaxle but with a solid input shaft and a AC specific bell housing bolt pattern. The tandem chain cases while rectangular on the AC and oval on the Galion are oval, will interchange. Hint hint.
I’m pretty sure, but I’m not certain.Thanks for the confirmation, I greatly appreciate your help.
Just to be clear, the Rockford clutch and pressure plate are 11", correct?
Galion 503Hello I'm new to this forum. I Just bought a 503 galion and am wondering if there are front scarifier mounts or something for a dozer blade or snow plow for these small graders? There's a flat plate with holes on the front. Does anyone know of a setup laying around in a scrap yard somewhere or a junk machine? Also any information about the machine would be appreciated as I've only operated newer much larger county graders. Also what is a reasonable priced tire that works good for these? It's a 10.00x20. Thanks this is an interesting forum!
