.....Fuel......
cheyenne
ny
Is it true that Diesel fuel & fuel oil are the same thing & if so I can burn fuel oil in my equipment. Since diesel is $4.50 Gal & I can buy fuel oil for 2.50...........Or has someone been blowing smoke :beatsme...Cheyenne
mitch504
Andrews SC
where you buying fuel oil for $2.50? i'll take a transport of it
:yup
The oil companies claim one or the other is cleaner, or more refined, or has been blessed by a wizard, or something; depending on which they are pushing.
My Brother-in-Law was furious this winter because they made a delivery of off-road to his shop, then drove 150 yds and made a delivery of fuel oil to his house, without changing anything on the truck; When he got the bill, one was $1.55/ gallon more.
cheyenne
ny
I belong to a co-op: Fuel Oil is $ 2.50 Propane is $ 2.01 The prices do fluctuate with the market & right now the market is high.......Cheyenne
Dirt Dogg
Illlinois
Owner/Operator
Fuel oil and Diesel Fuel are not the same. Fuel oil looks and smells similar but the flash point is lower and closer to Kerosene. It is used for home heating because it burns cleaner and the gelling properties are lower. Our Winter Blended fuel is a ratio of 60-40 to prevent gelling and aid with starting, you can tell there is a power loss when you use it.
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
I think this is probably the most accurate answer! I've burned fuel oil in my off road equipment for 25 years with no fuel related problems provided I winterize it for cold weather. The off road diesel at work is the same exact red color as the fuel oil in my home heating tank. I have to be convinced they are different products.
akroadrunner
Alaska
Gravel Pit/ Trucking/Owner
The difference is the TAXES. If you burn heating oil in equipment or trucks you risk some very expensive fines.
da'yoop
upper michigan
I can understand a fine if you used fuel oil in a truck that's being used on the road but not if it's used in off road equipment like dozers or whatever.
Speedpup
New York
President and all else that needs done!
The lubricity is different in home heating oil and diesel fuel so you will wipe out you injection pump faster. You can add additives to help.
watglen
Dunnville, Ontario, Canada
Farmer, drainage and excavating contractor, Farm d
I always thought it went like this. From highest (most refined, filtered) to lowest grade (less refined, filtered) Kerosene, then #2 Diesel fuel, then home heating oil.
I have run diesel fuel in my furnace for years, and have run kerosene in a diesel engine, without issue.
But modern engine fuel injection systems have so much lower tolerance for impurities, lubricity, etc, i wouldn't use anything but "proper" diesel fuel in my stuff. But that's just me, i'm not a risk taker when it comes to my equipment.
95zIV
Cincinnati, OH
RR Contractor Super.
Off road fuel, and heating fuel are the exact same. The only difference in them is what you wanna call them.
cheyenne
ny
I found this on the U.S. Department of Energy Website......Diesel Fuel Oil & home heating oil are both Distillate Fuel Oils. The primary difference is that on road diesel fuel has a lower maximum Sulfur content & is subject to federal & state motor fuel taxes. Diesel has slightly higher cost. excluding taxes, than high sulfur distillate or home heating oil......SO......Now we know they are not the same thing.......The question now becomes can we burn high sulfur content home heating oil in off road equipment without any problems........:Banghead........Cheyenne
mitch504
Andrews SC
That's an easy question with two answers:
For pre-2007 equipment, absolutely. For a hundred years, all diesel fuel was high sulfur, then in 2007 on-road fuel became low-sulfur (less than 500 parts-per-million). In 2010, off-road fuel became low-sulfur (less than 500ppm), and on-road became ultra-low-sulfur (less than 15ppm). There are actually several reasons that high sulfur fuel is better for older equipment.
For newer equipment, I believe so, unless it has particulate filters or other advanced emissions equipment. Maybe someone that has more experience with newer stuff will speak up.
I believe this to be a moot question, at least in the US southeast, because at the three distributors I have checked, it all comes from the same tank. The owner of one of them says that it is the standard practice here.
bill onthehill
pa/ny border
I have delivered thousands of gallons and it is all the same fuel. Even the heating oil is low sulfur now. Most distributors don't have the tank capacity to segregate it anyway. Where you have to watch out is in the bio blends as gelling problems are greater beyond B5. The kero will also run fine with a decrease in power. It is more noticeable in dozers and track loaders. I run a blend year round with minimal filter issues.
Tony H
Long Island, NY USA
Speaking of Gelling... I'm new to diesel. At what tempuratures does one have to start worrying about buying Blended diesel or adding Anti Gel? Geeze, Diesel used to be teh cheap stuff, now , in New York it's priced higher then Premium gas. It's refined less than gas, how can this high price be possible?
