Countryboy
- Joined
- Jun 8, 2006
- Messages
- 3,276
- Location
- Georgia
- Occupation
- Load Out Tech. / Heavy Equipment Operator / Locomo
I'm not familiar with Metabo. Where do they sell those?
Hell Hotsacks... don't buy new grinder... go buy a digital camera and post a picture of the pin thats been stuck for almost two weeks
I had some major issues removing some pins from my Case 9030B .. tried all of the above and it moved 1/2 Inch .. Heat. cold, Presses, torches, hand mauls, and sledge hammers .. I put 30 + man hours into trying to get it out ... I ended up using a skidsteer mounted jackhammer .. the pin was out in less than 10 seconds .. Live and learn .. good luck
i use them they r great not cheep but seem to hold up to me and i get them at my welding shop u can do a net search
i belive they r german
I gotta say thanks for this thread. I have been reading it for, oh, about a month now, and I am amazed it is still going and the pin is still putting up a valiant fight. Someone mentioned way back on page 2 or 3 (eons ago) to nip the pins off with a Stihl quick cut - that's about 20 minutes, including mixing the gas. Then, take the cylinder with the chunk stuck in it to your local 50 ton press, let him work his magic, and carry on - about another 45 minutes, including the time needed to tell the press operator this the whole agonizing story.
I hope my humour is coming through - sometimes we can take a 1 hour job and turn it into a paycheque.
John from North Bay, Ontario
I guess I'll add my two cents in. Learned this aboard ship in boiler room. Had two men with butterfly tips heating shaft. When it was red to the point of shining, third man hit it with a fire extinguisher. The fourth man then hit it with the B.F.H. Works everytime. If you were not in the navy and don't know what a B.F.H. is sorry, I can't tell you on this post
Take a torch and heat the sleeve around the pin, you have to be carefull not to heat it to much or the pin will expand too. If you heat it enough without the pin getting to hot too the sleeve should expand enough so that you can drive the pin out. Use a smaller pin to put against the pin you are going to drive out and hit that pin with the sledge , this will minimize the mushrooming of the pin. If you get the pin too hot too then take a spray bottle of water and spray on the pin to cool it a little bit , this usually will break the bond of the pin. You might have to heat and cool several times to get it to break free.
Hope this helps.
