Willis Bushogin
how about fuel filters,
I thought the primer pump was located on the fuel transfer pump. Ive had tow of these engines, but I cant think if this was the case on your engine. Sometimes these engines has two fuel filters, one might be kinda hard to find, usually mounted kinda in the chassis area.
I would think if the primer pump works, the regular pump should work, but theres always a chance something else, might have happened. If your suction line is on the bottom of the tank, cut the valve off and remove the hose from the tank. Using a bucket, of course, open the valve and see if fuel comes out. Dirt, debris, rags will stop this up.
Last trace this fuel hose, to the engine, it should go through a filter first, if so take the filter off and blow the line out and continue toward the engine.
Fuel pumps do go out, but I always check other things first. Did you just change fuel filters? Ive had mechanics either install a gasket, without removing the old one and not installing a gasket at all.
There is a good thread going on about fuel filters half full, good info there that may help you.
Good Luck and keep us posted
