shopteacher 1
I have a ford 4500 backhoe. The power steering pump has enough fluid. When turning, it has power steering when turning right, but is hard to steer when turning left.
Any ideas?
Any ideas?
When I looked at this picture I remembered that if the cylinder anchor pin nut gets loose it will cause this too. It is under the front end casting. I can't remember if there is a way to hold the pin and tighten the nut or if the pin is locked, but I'm sure you can tighten this nut from outside. I would have looked to see but it was pouring rain when I left the shop.
Good Luck, Mitch
:BangheadI scanned the instructions for adjusting the valve and have tried everything but hanging from the chandelier to post it. I tried it as a pdf and a bmp and couldn't get it to a size the forum would take. Send me an email at
natural_nutrients@msn.com and I'll email it back to you.:Banghead:bash:bash
I have what I think is a ford 4500 back hoe. It's older than dirt and wore out, but runs great. I recently have started losing gears. I've lost all but 4th. I can still get it into 2nd, but as soon as I put it in forward or reverse it grinds and kicks out of gear. I can't even find 1st or 3rd. Any help would be appreciated. The beast isn't worth a plug nickel, but it's invaluable to me.
Thanks.
