I've actually been putting off my swivel. I can't decide if I want to try to leave it in the crane, and leave it wired, slipping the new rings over the wiring, or just pull it all out, and re wire it. It mostly just drips a little fluid when its cold. It leaves a puddle about the size of the bottom of a 5 gal bucket when it sets overnight. Once its warm (hyd oil) it stops.
Every time I've tried to leave a swivel in the crane when resealing, it ends up leaking.
I have 3 quick connects on the frame for the wiring though, and it looks like I could drop the inner hyd portion, leaving the outer can on the crane. Then thread the old seals off, and pass the new seals over the wiring, doing it all under the crane, then jacking the inner back up into the outer.
I also have the female of the quick connects upstairs, I've thought about undoing both, then just fighting past the wires out on the shop floor rather than in the crane. I don't have air or water in my swivel, so it's not too many ports. I think 12-14 or so.
I know I'm not starting replacing it tomorrow, because the crane is going out to set trusses. Then its got a tree job next tuesday. I'm not sure I want to tear it apart on friday, hoping I get it back together and working right by tuesday morning. I'll probably just wait till after the tree job. And then there's a cell tower the thursday after. I don't imagine its going to heal itself.
It would be even nicer if I had some tools left to fix it with.:Banghead
