Field service guys.
fixou812
Buffalo NY
Millwright Equipment Mechanic Welder
I believe they're called mono goggles those with a face
shield work good if you're doing alot of grinding.
kshansen
Central New York, USA
Yep, those glasses with the seals are great. Worst issue I ever had was a tiny sliver of steel in one eye after laying under a light truck drilling holes while installing trailer wiring. Had goggles on the whole time thought I was bulletproof. Must have gotten in through the little air vent squares. Didn't even know it until the next day, by noon I was at the ER having it removed and the rusty spot around it dremel tooled to clean it up. Not an experience I would care to repeat.
I've be lucky never had that happen but one day in same position had a steel shaving go in the ear, could hear it sizzling for a while. Was lucky it didn't get stuck and came right out. Not that there is much between the two ears to have it hang up on anyhow!:falldownlaugh
Former Wrench
Montesano, WA
Retired
I was always into carrying hardware to get things done; shackles, lifting eyes, chain and chain binder, a little bit of plate steel, some cold roll, bolts with the heads cut off for line-up studs, a come-a-long and other that I found helping me out from time to time. Remember your hands. You only have two chances to error, the right one and the left one. Don't put them anywhere there is a chance to get them bitten off. Good luck.
wornout wrench
canada
Love the hot slag in the ear when welding.
Had a friend that lost the hearing in one ear when a he got some slag in his ear. He said it was the loudest and last thing he ever heard out of that ear.
I wear ear plugs all the time when cutting or welding now.
GregsHD
Mahood Falls, BC
Self Employed HD Mechanic
When I was young and stupid starting out, an old boy teaching me told me to always wear ear plugs while welding or cutting with the torch, but he didn't tell me why, knowing full well that i'd figure it out PDQ, and I did!! Makes me cringe just thinking about molten slag sizzling and bouncing around in my ear!
RobVG
Seattle WA
17 excavators and a stewpot of other stuff
Anyone watch the car restoration shows on cable? These guys don't wear gloves when grinding.
I guess they've never looked down on the back of their hand and saw a white streak and beads of blood staring to form. I figure the burning sensation alone is enough to want to wear gloves.
But I guess they're just that good.....
old-iron-habit
Moose Lake, MN
Sss
Somehow I suspect their grinding time is for a very short duration. Always see them guys welding without a hood also while tacking. Makes me think they are not that good if they are that careless.
crewchief888
NWI
i've been wrenching at const eq dealers for 30 years, spent over 1/2 that time in the field.
i've been in everything from a chevy luv pickup to f550 SD trucks.
heres my suggestions.
most pertain to cold weather
water, water and more water, even in the wintertime. you can easily get dehydrated in 0* F temps. i easily go through a gallon every day.
food/snacks, i dont eat much at all during the day, but there are those times when you have to have something to eat.
warm & dry gloves, extra socks, extra pair of cold weather boots, rain jacket, extra pair of insulated coveralls or bibs.
keep your phone charged
if you use cordless tools, spare batteries, or an inverter and charger(s).
keep in contact with your supervisor, so he knows how things are going. if i leave in the am and are headed to 3 calls, we have a "time frame" of when i should be done, in case theres an "emergency".
i dont keep my phone on me while i'm working,
but i check it when i grab water, or as soon as i get back into the truck.
we have our (work) email synched to our (company supplied) phones.
sometimes things dont go as planned, (sh*t happens), my customers appreciate honesty, even if it means the machine will be down until parts come in, but we try to get everyone up and running ASAP.
i think above all, maintain your sense of humor, even when mr customer is furious.....
:drinkup
DARO
Duluth MN USA
Mechanic
Good luck. And have fun. Cuz when u get there. The bad day is probably in full swing.. :)
Volvomad
Ireland
Former Wrench hit the nail on the head with an assortment of studs. when working alone as I normally do in the shop or field can be as good as a spare pair of hands for heavy components .
adam.p
Vancouver
Always keep a stash of stuff to eat in one compartment along with a case of bottled water, some jobs turn into marathons and always happen where there's no stores or places to eat. Electric cooler is good, if you have a welder/generator a mini microwave is priceless. Probably not the kind of advice you're looking for, but my attitude goes South real quick when a four hour job turns into twenty and my stomach thinks my throat's been cut. Change of clothes doesn't hurt either. I have taken oil baths that soaked me to the skin even wearing coveralls. Diesel is the worst.
If you're working jobs where there's nobody around (I did constantly when I was in the field) develop a habit of thinking to yourself before every procedure "Now if I do this, what could possibly go wrong and could I be injured or trapped in some way?" We've all heard the stories of techs loosening hoses and ending up crushed or suffocated by whatever came down. Same goes for driving pins out, removing belly pan bolts, blocking machines up, you get the idea. Safety is always top priority, but in the field even more so and it's more challenging.
Good idea to keep a sidearm handy in the truck, YMMV, but you just never know when some form of two or four legged animal might need talking to in a loud voice. Some may find that distasteful, but like a fire extinguisher I'd rather have it handy and never need it than desperately need one and not have it. Oh yeah: CHECK YOUR FIRE EXTINGUISHERS AND FIRST AID KITS at the start of every day. The one time I really needed an extinguisher somebody had used mine and politely put it back in it's holder, empty. Wasn't much use to me.
Keep your sense of humor, you will undoubtedly be dealing with all manner of people out there in all kinds of moods, be professional, polite, a calming influence, and the kind of driver that assumes he has to keep everybody else around him safe because they're not smart enough to do it for themselves.
Lastly, have fun! It's a completely different world from working in a shop.
:cool:
This is the best advice I have ever heard for a field mechanic! Especially the part about a sidearm, I had an ecounter with a cougar while out doing a service in the bush.
monster truck
cali
A lot of good advice here, but as someone that world alone a lot I will add to keep your cell phone charged and on you! I learned the importance of that one first hand and now try to always make sure I have it on me while working. Also, don't drop it out of your shirt pocket and into a pond, that sucks too.
chris_james
Ga
The part about a microwave is sound advice. I get tired of sandwichs or if im running behind being able to crap some instanc stuff would be great. Ive thought about doing it. Just making room for it on the truck is the hard part. Ive spent a bunch of 12 hour days on a service call with no lunch. Seems to be easy one then two or three other tractors go down while im their.
nowing75
coatesville indiana
I took the passenger seat out of my KENWORTH and I'm going to make a frame that the microwave will fit under and access with the passenger door open,going to put a cushion on top in case I have to have a passenger. Don't have it done yet so no pics.
lantraxco
Elsewhen
Nothing like a grilled cheese sandwich made on a hot plate... piece of steel plate heated with a rosebud, LOL
Wes J
Peoria, IL
Back in the day I worked for the township road department. When we hauled asphalt the guys would pick sweet corn out of the fields and toss it in back with the hot asphalt. By the time you dumped it it was nicely cooked inside it's husk.
kshansen
Sounds just like a welder we had at work years back. Heat up a piece of 1/2 plate clamped to the bench in the shop and cook his lunch.
Then there was the guy at one of our plants who ran the drill rig. I was helping him pull the 8V-71 that snapped its crankshaft, yea it still ran! Anyhow while removing the exhaust he told me to be careful with that bent up piece of something like 1/4 steel rod that was hanging on the one manifold. Said that is a very important part of the machine. Asked him what it did. He said around 9:00AM you stick a can of beef stew or chicken soup in the bracket and come noon time it was just right to eat!
