John C.
The brand of engine has not be stated yet. Most of the Hitachi excavators in the States have Isuzu engines but I have seen a few with Hino engines. The Isuzu plants are bullet proof but the Hinos are nothing but crap. I've had more than a few headaches with these.
Finding out if there really is a leak as has been suggested is the least expensive item and a very good place to start. I have one of those radiator testers in the truck all the time. It is a radiator cap with a fitting that is connected to a hand pump. Before start up I pump up pressure on the radiator and watch it for leak down. Many times it will leak off very slowly making me wonder if it is my pump. To check that I'll drain off the pressure and then reset the cap. I'll pump up about a pound of pressure and then start the machine. If I'm getting compression it will show up on the gauge right away.
One other thing to do is take an oil sample and send it in for analysis. Anytime a head or liner leaks it shows up there.
Good Luck!
Good Luck!
