Falling Scrap Iron prices
Old Doug
Mo
I was surprised that there wasn't much of a pile at all when I hauled my load Tuesday. They probably just sold it off and trucked it out, but I don't think I've ever seen their pile so small.
I dont know if they got a price locked in or are going to save it till it gos back up. It never went well when i stock piled it.
IceHole
AK
I just throw my scrap in the trash.
In case your wondering, the bottom of those wheel bins can and will fall out if you put several hundred lbs of semi truck leaf springs in it
I can't wait to see this nasty pile/piles of crap a friend owns scrapped, his place is just a mess.
Old logging arches, piles and piles of old axle housings, frames just nothing but junk and a
eye-sore--Those old KW's--there isn't enough good pieces to even make one. I want to be
there videoing when those go--most of those are so rotten the paint is holding the metal together.
It will take a solid 6 months to a year to clean it up, unless a shear is brought in.
IceHole
AK
View attachment 307329View attachment 307330View attachment 307331
I could use a set of log bunks for a log truck I have
Previous owner just stacked what would stay i guess. Had a flatbed they never bothered to attach to the frame
Birken Vogt
Charter Member
Grass Valley, Ca
I did that once, the bottom of the bin did not fall out, but the crash it made when it hit the inside of the garbage truck was tremendous. He must have been empty when he tipped them in over the top.
IceHole
AK
We threw an old Cummins 220 block in the dumpster. Same deal. Probably dented the floor of the truck. Whoops
Cheap "old" Geezer
Had the grandiose honor to unlock a Compactor blade in a Leach body, was bound up on a small pile of engine valves from a trash can. Lovely day at the dump.
stinky64
java center ny
big truck wrench/fixer of things
Rust museum.
stinky64
java center ny
Same, but was McNeilus body, piece of rebar stuck between the blade and the body with a big hunk of pointy concrete attached was tearing a hole in fairly new truck. Had to exit landfill back to shop, cutting torch and loader chained to blade remedied that mess. New equipment manager not impressed. :rolleyes:
Cheap "old" Geezer
We used a shove dozer in the Dump as truck was Gate end up and around half exited, used a old utility pole to dislodge the damn packer/discharge blade then proceeded to wade thru nasty land to clear the disaster.
Cheap "old" Geezer
Garbage, old rank pieces of molding whatever, even restaurant dumpsters that smelled like puke. The one that always got me were when had mounds of disposable diapers. Could work up a good heave from those nearly every time!!
