Engine blow by
Tomvarner
Oklahoma
How much blow by is normal? I have enough to make a mess of the underside of the backhoe coming out of a vent tube off the side of the crankcase. It is a 1991 Case 580K with a natural aspirated 390 CI 4 cylinder. Starts and runs great. Hasn’t been using much oil up till now. It’s due for an oil change soon.
Blow-by is measured by a gauge--inches of water. But some engine manufactures don't
list a value. Just how bad is the cloud? And how many engine hours does it have?
Tomvarner
Oklahoma
There isn’t a cloud. Just dripping oil. The engine hour meter has been disconnected since I’ve had it. You don’t want to open the fill cap with the engine running or you will get sprayed with oil droplets. If that gives you an idea of how much blow by.
Georgia Iron
USA - Georgia
Concrete building slab and grading contractor
I bought another motor grader with a Cummings 4bt in it. When it is running, it will spert a little bit of oil out the fill tube if the cap is off. Does not smoke once warm but does when you first start it. Seller claims smaller diesels do that. My other machine does not. I got a 5k discount on the purchase because of that. What do you guys think about a small amount of blow by.
More than likely, this machine has sat for a while because it does not look like it was used much. My other machine has much more wear in the assemblies.
I bought it as a spare for parts but it looks good enough that it could be set up to run as a second. Not sure if i should get into the engine or not
Could have sat for so long, the liners are pitted and the rings screwed up. As long as it stays running for what you want, everything is good.
We ain’t running Lambo’s here.
Tinkerer
usa
No question is stupid in my world.
The injectors need to be removed and then a compression tester that has the correct fittings for a Cummins 390 is needed.
There should be a lot of information on web (YouTube) on how to do it.
Harbor Freight may have a test kit. I never have looked.
Tomvarner
Oklahoma
I was afraid of that but didn’t know. You know I never suspected low compression because of the way it fires off on the first crank. Also there’s no puffing or excessive smoke.
What should you be seeing from a good engine in respect to the fill tube blowing out oil? Does a new engine have any blow by?
I guess I’l get out the service manual and read up on injector removal.
davejo
va
Cummins measures their base pressure specs with a blowby orifice tool with a .221" (15/64-in) outlet. Or, make your own and hook your manometer, if you are curious .
126 L/Min(10.5"rise) @ 2200rpm
152 L/Min(14.5"rise) @ 2500rpm
170 L/Min(17"rise) @ 2800 rpm
.22 LR shell with the end cut off could be the start of a redneck orifice?
