It's a whole big operation for me to run ET as I have to replace the disk in my laptop since I normally run Linux.
After this latest test it looks like I'm punked, skunked, and defunct. No clear answer.
Have the whole system back together, removed the injector and put it in a baggie, and started the engine 3 times, each run being about 2 minutes. All that was in the baggie is the first picture. That doesn't look like I think it should be after 3 starts, although it does smell like DEF.
Second picture is ET SCR 1. Terrible pressure. Its behavior is clear: the pump runs forward for 1.5 minutes, then stops and reverses. There seems to be enough volume and pressure when forward.
So if the pressure reader is wrong, there is not enough fluid in the baggie because it's just circulated at first? It would make sense for them to do that. It doesn't seem possible to order just the pressure transducer as I believe it's in the pump assy at the outlet, which is $2,500. Can I hotwire the transducer if it's bad? If it's just a switch, surely so.
Pulling a vacuum. I have a shop-vac. I've run over the DEF cap (left it on the track) and that's $75, so I have only a baggie stuffed in there for now. I do have an HVAC vacuum pump, so maybe I could rig up a cover with schrader fitting and put my pump/gauges on it. I'm 90% sure my system is closed, but it may be worth testing.
This is the sum of what I know after carefully going through every stage of the system in detail. It's good to have confirmed that DFP regen is inhibited because of this, although now I'm at Stage 2 of a plugged-up DPF. Not long before Stage 3 and I have to disassemble the whole top of the machine to remove and try to clean the DPF. (although back-pressure is zero)
