J.Freeman
Hi all! I'm Jeremy! Im a Taurus and I mess stuff up! Ok... now to be serious, I am in need of an electrical diagram of a jd 310j 2008. I'm trying to find an op and test manual but they say 10 days before I can get one.....too long to be down. Dealer says they print on demand....used copies are just as much almost and take as long too. Here's the problem, code 110.04 Ecu engine temp sensor fault. Found out the voltage it was to be running and checked it. It was below the 4.9v which indicates a wire damaged, short to ground, the gauge, or the ecu of 2300 bucks. Trying to find where the wires from engine temp sensor go to...keep in mind I'm an electrical idiot. #2.. Flc 737.12 i cant remember what that was. Torque something solenoid short I believe... Here's the story. One of my coolant hoses to heat exchanger blew and got coolant all over underbelly. Got several things saturated. It worked fine for a day then started shifting into neutral and staying there until I turned the machine off and restarted. Kept doing it so I kept restarting and quit shifting selector out of 1st gear. Did fine as long as I didn't shift.when I had to reverse, sometimes it would kick it in to neutral. I took the plate off front of transmission to reveal 3 solenoid. Had 4 wire lead connectors but only 3 solenoids, anyhow I unplugged and noticed oily residue in them, cleaned out with starting fluid, cleaned solenoids up, they had an 1/8 inch of dust and oil/coolant built up on them. Still had shifting back into neutral problems. Need any help out there please! Thank you for reading!
Jeremy Freeman
Jeremy Freeman
