Ed's 77 Terex 72-41
mountainguyed67
Fresno, California, USA
Everything looked like it went up and down. I turned the key, I didn’t have a wrench with enough leverage to turn it over by hand. And not a big enough cheater. Two cylinders had a little slack in the rockers, two were tight.
3FB661CB-EEDD-4BB6-9475-E5A4DF3F3959.jpeg 14EA71B5-0813-4769-9536-E82647F575E3.jpeg 322E0134-614A-4797-BBD4-A7837F272ADD.jpeg E782D995-7E3A-40B0-B771-CF3435E504FD.jpeg
56wrench
alberta
the centre rocker lever of each group of 3 is the injector. also check for cracked injector lines. they usually crack around the flair under the nut. usually caused by overtightening which may cause eventual failure. were you able to tell which cylinder is running cold?
mountainguyed67
I looked at the lines, but not thoroughly. And not by the flare. Wouldn’t a cracked injector line add diesel to the engine oil? There’s no evidence of that. The cylinder closest to the bell housing is the one running cold.
56wrench
alberta
as far as leaking a lot of fuel into the crankcase, it would depend on how long you ran it after it started missing. also check for a bent injector push rod on the bad cylinder. i think i had that happen once in a 4-71 but that was 40+ yrs ago and my memory isn't as good as it used to be
mountainguyed67
If the push rod was bent enough to be a problem, wouldn’t it be obvious? They all looked even, to the eye anyway. I’m thinking I need to switch two injectors now. I haven’t looked that up in the manual yet. I should be able to go back up in a few days.
mountainguyed67
Id think you will see the problem by popping off the valve cover. Ive had injectors stick before.
I really didn’t pay attention to the injectors, and ran out of time. I will look next time, and try to talk my son into going to help. Otherwise it’ll be tough to turn the engine over by hand, and look at what’s going on at the same time.
56wrench
alberta
Well, yours is not quite the same. Yours has a 4 valve head and the rigid levers on the rack control tube. The 6V71 in the video has 2 valve heads and the newer style spring-loaded rack control levers. The governor setting procedure may also be different depending on what governor yours has
56wrench
alberta
You could swap injectors but be aware that when you do that you will have to set the injector timing with the special timing pin and adjust the rack control levers on both the injectors you swapped
You really need to come up with something to let you turn the engine over by hand so you can stop it while the two outer rockers on the cylinder in question are all the way down on the valve bridges. Then check to see that there is no gap under the rocker for the injector where the red arrow is pointing in the picture.
Also I would suggest removing the pin in the linkage where the yellow arrow is pointing, be very careful to not drop cotter or the pin it's holding in! Then work that tube by hand to see that all the rods coming out of the injectors that the levers work and coming in and out nice and free on all the injectors. Forget how much they move seems like it's about 1/2 to 3/4 in travel. Main thing is that tube that work the injectors works very free.
