Dump truck yoke questions
resource_19
Atlanta
Disclaimer: I know almost nothing about dump trucks. However, I need to know what is the function of a yoke on a (1980's Freightliner) dump truck. Also, what can cause a yoke to break (i.e., weight, shifting, etc). Thanks in advance.
Multiracer
Northern,Ohio
Owner/ operator
Driveshaft yoke ? They are found on the output shaft of the transmission and input shaft of the rear differential. The other half of a U-Joint is held by a stationary yoke built into the driveshaft. Drivelines in dump trucks take a beating !!
Ron
resource_19
Atlanta
Yes that sounds right. What is the purpose of a yoke (in layman's terms)? Does it relate to movement of the rear wheels?
Phill
Nanaimo BC
land Survey Assistant
The yoke allows the Drive shaft to change its angle with out binding up, as the Rear wheels move up and down with the road or terrain the drive shaft angle changes accordingly. If its not able to change angle it would stop spinning and not allow the power to go from the engine to the wheels. i am not sure how else to describe it....
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
The yoke holds one half of the universal joint which allows the driveshaft to flex. I've posted them below, both unassembled and assembled. The most common cause of failure on dump trucks is a sudden application of torque while carrying a heavy load. All starts and transmission shifts have to be done smoothly to avoid drivetrain damage with heavy loads. Another cause could be the failure of the u-joint itself due to age or lack of maintenance.
The yokes pictured are from cars, the ones in a dumptruck would be of the same design only much larger.
