I want to drain all the old coolant in my tractor since I'm replacing a hose. The rad. drain works fine but I want to drain the block as well. There may be a block drain but it's nearly impossible to get at with the loader frame in the way. I have a heater mounted on the top of the cab. I was thinking I could pull a heater hose(s) and blow air into it to blow the coolant into the rad where it will drain. I'd leave the rad. drain open. I don't really want to remove the lower rad hose incase it is stuck and gets damaged trying to remove it. I don't think there's much chance of over pressurizing the cooling system just using a rag or something around a blow gun. I could regulate the pressure down though. Would this work and is it a good idea to get the most old coolant out?
