We have tried to power the solenoids, no problem there, but what you have is NO flow to the valves. It seems that I need a diverter valve. where I can swap the flow from the blade angle cylinders to the tilt cylinder. the only hitch in this plan is that it seems that Cat is using hydraulic pressure to hold the blade at angle. Craft you say that you done this ? is this what you needed to do? As far as the ability to doze with this blade this is only for use at Deer camp to maintain roads drainage ditches and parking lots. It should be ok for that.
Look …..from what i'm seeing in the pics you provided is you have a manifold there that is requiring continuous flow triggered in the skid ……… from there the diverter valves supply hydraulics to either of the cylinders ……. the diverter valves are already those 2 units on top of the manifold …… I don't have a Dozer blade …. BUT I have a Blizzard 8611 pp, which is a snow blade that can angle left and right, as your dozer blade, it has 2 more functions that extend either or both wings out to widen the blade from 8'-6 out to 11' wide ….. these cylinders are double acting as yours are (other than mine has one more elec over hyd function at the hyd manifold than yours) ….. mine was a wiring nightmare for me, i'm no electrical engineer, LOL, but I had the OEM manual c/w wiring schematics that came with the new blade, Blizzard does NOT have a factory made harness that plug-n-plays for every skid-steer out there……. so I had to create one (which I did) I made dozens of ph calls to every where, Bcat dealers in the States and in BC,Alta,Ont. trying to find a dealer that had done this match-up Quik attach, Blizzard, you name it I called them ……. this was not the first time for me either …. the first time was when I bought the Hi-flow Buhler snowblower, again I had to figure out matching the 14-pin functions to the Bcat, on it there are 2 hyd motor functions and 1 hyd cyl to tip the deflector up and down …..
Both of those attachment were NEVER meant to Plug-N-Play into my Bcat or any other skid-steer for that fact ….. they BOTH had their own generic hand controlers which you Mickey Moused thru the door to their own controller ( PITA ) …… I paid big bucks to have the machine with all of the joystick buttons and wanted them to operate my attachments.
Both of those attachments had "1" common denominator …. they BOTH required continuous flow from the Skid to the Hyd Manifold, from there the flow is DIVERTED to the other accessories/functions as it appears in your case by the pics ….. they DO NOT use hyd pressure to hold a cylinder from moving the diverters are a valve that open and close at the manifold ….. they usually open/close in pairs (1 in and 1 out) then when you let go of the joystick button, they shut off holding the hyd oil in place where you chose to leave it (positioning) …..
Get the original owners manual for the CAT dozer blade (which is probably made by BRADCO) …. you may be able to download it off of either Web site …. or maybe a dealer can send you one in PDF form ….. either way you need to see a wiring diagram for the blade ….. you will also need one for your Kubota Skid-steer ….. otherwise you'll need to know WTF you are doing in order to figure out the combinations of pins you need to make everything work "Very Time Consuming" when this not your forte (as in my case I didn't know wtf I was doing when I began …. LOL)…….
OBTW ???? ….. did the blade come with a remote to stick (mag mount) in the cab ??? ……. because quite a few machines DO NOT have joystick control functions built in or 14-pin connectors, so they make a generic hand controller, alls you need then is 12v power ……
