watglen
- Joined
- Apr 3, 2009
- Messages
- 1,324
- Location
- Dunnville, Ontario, Canada
- Occupation
- Farmer, drainage and excavating contractor, Farm d
Volvo EC240B
Air conditioner clutch blowing fuse and kills the whole cab ventilation system.
I diagnosed it as a shorted out ac compressor clutch. It happens, and the machine has 5000 hrs on it. Makes sense.
Have the guy out to replace the compressor/dryer/r134 etc. He did but didn't fix the problem.
For whatever reason, he opened the loom at the compressor clutch and found a power diode.
I checked the wiring schematic and found it shows a diode around the AC compressor.
Odd thing, unplug the diode, fuse blowing goes away. AC is working well.
I don't know anything about diodes, but I tested with my tester. 72 kohms in one polarity, infinite ohms in the other.
Can anyone explain what is going on here? What is the diode for, what happens when you remove it?
