Hi everyone!
This is the first time I am messing with screw compressors. I am working on Atlas Copco XAS 185 (JD 7).
The problem is it seems to activate idle down cylinder earlier then supposed to.
It will unload, idle down and maintain the pressure if I abruptly close the discharge valve.
But it will start to activate idle down cylinder and reduce speed and power right around 85 psi. It is set for 125 psi.
Very often it will kill the engine close to rated pressure.
Atlas tech support said that spread between unloaded max. pressure and going back to full RPM should be 15-20 psi.
So if it is unloads at 125, I supposed to be back to full speed at 110-105 psi.
Don’t think it is an engine performance issue, and don’t really understand why idle down system reduces the engine power right when it needed the most.
This is NOT solenoid unloading machine.
Anybody have any takers?!
Thanks in advance!
Thanks in advance!
