Detroit 471 Reverseing
SE-Ia Cowman
Iowa
I need some input from Detroit experts.
A customer brought me a 471 Detroit today, it came off a water pump from the local water works and only has 138 hours on it, I assume it is from the 70's. I purchased a jensales manual that is a exact copy of the Detroit service manual. The question is we need to reverse the direction according to the Detroit book it is now in the RB configuration. I need to get it to the LB configuration the book explains the timing and I know I need to move the idler gear to the other side and will have to change the plumbing on the oil pump (IE switch the pick up and pressure to opposite sides of the oil pump) But the book does not cover how to change directions and what parts you need. Will I need a different cam? will the fuel pump work? do I need to put the blower on the other side of the engine?
Any help would be greatly appreciated
Old Doug
Mo
Its been a long time ago but i am pretty sure the blower is on the other side. The place i worked had both siting side by side and they had alot of things diffrent. It had me thinking that it was a big job to change around.
Shimmy1
North Dakota
I have been told that some oil rigs had two inline 6-71's (238) side by side. They ran opposite directions. Blowers were on opposite sides as well. My guess is this is going to be an expensive problem.
partsandservice
Georgia
I have built a couple of detroits but I am not an expert, but I believe it is simply how they are assembled . You will have to have left hand fuel pump also. I have heard tale of them being build backwards by accident.
mitch504
Andrews SC
The blower can be on either side with either rotation. There's no such thing as a left hand fuel pump since it is just a lift pump, injection pressure and timing is created in the injector on a -71.
I don't think there is a difference in cams either. They will start and run backwards, blowing smoke out the air filter, but without reversed oil plumbing they won't do it long. A mechanical L10 Cummins with the PT pump will run backwards, too.
I believe you will find there is a different cam for the right hand rotation from the left. And also I think you will need to change the idler and crankshaft gears.
If you have the cam out of the engine there should be a number stamped in it Left hand engine cam is marked #5102666 right hand cam is #5102663
The RB engine should have a 5113817 idler gear, the LB would have a 5113818 idler gear.
The RB engine would have a 5113814 crank gear, the LB would have a 5113815 crank gear.
Once the correct gears and cam are installed the blower and fuel pump and governor can stay right where they are, blower runs off the cam and no matter the rotation of the crank the cams still turn in the same direction for both crankshaft rotations, that's why the idler has to move.
Note gears should be the same for 3-71 through 6-71 so if you can find a donor from any one of them you would only need to find the proper cam.
Note: number stamped on cam is not the same as the part number, if you need the part number let me know.
EDIT: I think you also must know that the starter will have to be changed as well. As cam turns the same direction on either engine the generator if it has one will not need to change,alternators don't care about rotation.
SE-Ia Cowman
Iowa
Thank you Kshansen that is the kind of info I was looking for, I have both starters, I will check the numbers on the cam and crank on Monday.
Not that it makes any difference I was wrong about the current configuration of the engine it is set up as RC now and needs to be LC ( exhaust on left side blower on right side)
SE-Ia Cowman
Iowa
Here is the Pic out of the service manual
SE-Ia Cowman
Iowa
Better picture
I circled the config I have and the one under it is what it needs to be
partsandservice
Georgia
When ordering fuel pumps in the past i had to specify right had or left rotation. I also looked it up and right hand and left hand pumps are listed.
SE-Ia Cowman
Iowa
water pump is driven off the blower so it does not need changed, because the blower does not change directions
If he is changing from RC to LC configuration the only thing that will be changing rotation direction will be the crank so even though there are right and left hand fuel pumps that should not be an issue for this engine.
As I said the thing that has me concerned is the oil pump and lines. Is there an original engine that this new one is replacing? That would make it a very simple project. Just pull the cam and idler gear and oil pump and pipes off the old engine. Head will have to come off to remove the cam.
SE-Ia Cowman
Iowa
Unfortunately this motor is not replacing another one.
The whole thing is really pretty silly in my mind. My customer bought this motor for less than scrap price and has bought a Allison transmission and has plans of putting it in a 3/4 ton dodge pickup. I know it is to heavy but not to worry I was hired to reverse the engine not install it.
SE-Ia Cowman
Iowa
I already thought about that but the Allison automatic won't like turning the opposite direction. If it were a manual I think I could convince him.
nowing75
coatesville indiana
Check out 4bt swaps fourm. Ther is a section on detroits that has every thing you wanted to know about puting a screaming jimmy in a pick up. I have a 453t that is on my list of projects.
partsandservice
Georgia
Did some research. This engine is reversible with nothing more than a gasket kit and starter. You have to swap the cam and balance shaft but not the gears they remain in their position, the idler gear has to be moved. The oil pump can be assembled to work either direction as well. All other acces can be mounted either way. There should be timing marks already on the gear for left or right hand rotation. Go to whaleboat.us , this is where I found the Detroit Manuel that I got this info from. I think this is what you are looking for as it explains how to set the engine up for the desired rotation.
