Hmmm, I remember a member here talking about food plots. He said using a wide track dozer would be bad for the food plots because it weighed more than the tractor.
I will say this. You can make pretty good compaction with a tracked machine if you spread material in thin lifts. Ive done some fills with clay in small sq foot areas. Small being relatively speaking. I needed better access to a topsoil pile. I pushed all the topsoil and mud out of the way. Then started pushing clay into place in about 4-6 inch lifts. Then tracked it in the with D6 I was pushing with. You should have seen the dirt cop flip out. He told me there was no way I could make density that the parking lot required. Had him test, I hit the numbers on the dot. Would I want to use a dozer to compact all my fills. Hell no.
I still think this dozer is more of a pan puller. To me it doesnt have a wide enough real world application. Cant use in rock, cant clear with it. Im willing to bet is better balanced than a Case quad track with that heavy blade hanging off the front. I wouldnt have a problem send a few to a job to strip topsoil, and maybe run my cut to fills. But with all those dozer blades on site, its going to be like having too many cooks in the kitchen, they are going to ruin the soup
