Deere high speed scaper ?
buckfever
southwest pa
what about road side grading and large finnish grading jobs. if the tracks can holdup got to be cheaper then wear and tear on a steel undercarige.
cummins05
Edmonton
Whats the need for a high speed dozer for spreading road stone? Doesnt a grader already perform that job already?
I can see a dozer operator being able to jump on and run it so then you would need a less skilled operator ( not saying a cat skinner is not skilled) to get probably close to the same production.
If this machine can do other light dozing it could also eliminate a small finish dozer on some jobs and you could not bring in a blade till the very end of the job if you even need a blade after the high speed dozer is done
you could then maybe save the cost of two machines
If I could not bring in a high priced blade with expensive operator I would.
Kman9090
Everywhere
LOL ^^^There you go^^^ What didnt you get about my post??? When you finish main line on a highway some spots will be high and some will be low! I dont know about you but i have never seen a blade pulling a pan, where if he had a low spot in the highway he could just go pickup a load of dirt and dump it where he needed it or if he had a high spot he could just wind row it up and pick it up and take it some where for waste! You usualy have to have a blade and scraper or blade and dozer, where this machine elminates one machine and one operator!!! Think about it then post!
Abscraperguy
Grande Prairie, Ab
Just a question for all you experts. I do some refurbishing of used tow behind sheepsfoot packers and I do also build some new ones. I have this design for a double 60in with big transport wheels that I've got engineered and stress tested etc. I've never built any of those cuz I'm not sure what the market would be, but are there jobs where you wouldn't need a full blown packer or a dozer and the two of them would work well together? Lets hear what you have to say.
cummins05
Edmonton
I ment as in the machine itself not pulling a pan.
If you need a scraper to move your base gravel around (witch this machine is supposed to be marketed for) you kinda messed up on your spoting loads with the trucks. I personally have never seen a scraper having to pick up a windrow a blade has left. we usally lay clay to grade with a dozer witch we could do with this. all the blade does a a quick finish pass witch im sure the JDHSD could do then we lay base and spread it to final with the grader (no scraper needed if its low we dump a bit with the cross dumps.
this machine with Gps is supposed to lay grade as close to a grader.
So in theory you could leave the grader at home or bring it in for a smaller amount of time Here a grader with a good blade hand is a very pricey machine. I in no way would hook a pan to it for any of these jobs it could stay spreading what other machines have brought to it. So in my eyes this machine pulling a pan is unproductive thats my piont of veiw have yours.
You could stand to be a little less arrogant with your response to people you would probably have a better time here on the forum. So really I got your post just don't see how this machine pulling a pan would be cost effective the way we do work.
bigrus
Southern Queensland Australia
Joystick attendant
Those "expensive" rubber tracks have lost me straight away. Along with 8 large idlers to boot :eek:
Might look good on paper/theory. :pointhead
Plus with the price of secondhand equipment at present :(
Yes we all have opinions and opinions are like..well we all know that phrase.:cool2 All members here on HEF need to respect others opinions and discuss it in a professional matter. You can disagree till the cows come home but do so respectfully.
Carry on.
245dlc
Heavy Equipment Operator
I doubt if this thing would be worth the price tag, There are always used Challenger's and other tracked farm tractors around that could have a Degelman blade retrofitted for doing light dozer work as well the tractor could still be used to pull sheepsfoot packers, discs, and land leveller implements. And a lot of the big tracked farm tractors have a lot more horsepower.
hvy 1ton
Lawrence, KS
That's a bell scraper tractor unloading after the quadtrac. They are built from the ADT parts bin and are more "construction grade" then the 4wd tractors.
Kman9090
Everywhere
Well down here we have a tolerance of a hundreth before they will even let you lay base rock. We can get the whole mainline cut to within a tenth with GPS on the dozers, but we still have to come in with a milimeter system and cut it down to a hundreth. No GPS system can get it that close. And when you have 13 631's hauling to one D6 it makes it kind of hard for the dozerman to put everything right on grade, you have to leave everything high, because you have no idea how much they will compact a certain spot. And its much easier to cut it off then it is to have to haul it back in a recompact it. So then after you get done with your run, which today was about a mile, you have to go back threw and cut it to final grade, if the scrapers are done using the road! So today we had to use the 6 to cut it down a tenth after we got done with the 31's and had a john deerepick up the windrows from the 6, this machine would come in handy for doing that!
Kman9090
Everywhere
And i dont know if any of you have worked around mud but when it comes to loading out mud the quadtrak design is hard to beat, a case quadtrack pulling one pan will go anywhere a wide pad 6 will!
245dlc
You notice how on those Miskin scraper videos and the John Deere video they're always working with nice dry dirt? You never see them working in heavy cohesive soils, like Manitoba gumbo, silt, or loon ****. (pardon my french if we're not allowed to swear lol) I wonder how well one of those Miskin scrapers would work here considering they dump like a dump truck instead of having an ejector like a garbage truck or a regular scraper. :rolleyes:
DPete
Central Ca.
Just have to put a hoe in the fill to unload em :D
Too what hundredth does the specifications require before you lay your base rock?
Bumpus
Florida
Disability / Retired
According to the video ... you can buy them with or without an ejector bowl.
Dozerboy
TX
Operator
We run plenty of those scrapers here and there a pain in gumbo. Good operators help but normally you just have to work the dirt that much more. Often you have to come to a complete stop or make more then one pass in the fill banging the can open.
One reason also it might work ok here is you can't cut grade out here with a blade very often it mostly dozer work. Road projects where they lime and flyash the subgrade is the only place for a blade here.
