92U 3406
Convert to full mechanical
The basis is designed obsolescence, make it go away to drive the purchase of newer to new mechanisms. Fabick when took in ECM for review and eval as well updating the 6NZ parameters, noted these modules will be obsoleted in less than five years, next gen engine controls will be all that is available and nothing for repairs on old units, engines worthless without.
This was brought up on national rural TV show (ABC Landline) and was never denied by Deere. But it's not just harvest, even sprayers can be monitored. Seems like they make a quiet buck on the side selling to 3rd parties. I've wondered if mother Cat have a similar thing going on under their maintenance monitoring system.Another aspect of this that I haven't heard talked about much is Mother Deere's access to real-time harvest data. They have full access to all the GPS guidance and yield motoring software in these new combines. They know what field you're working in and what the bushels per acre are before it even hits the truck. Sounds like an easy way to do some insider trading on the Commodities Futures markets...
Anything's possible with enough time and $$$$. That's the kicker.While I agree with the sentiment, please tell me how to do that with electronic unit injectors.
Thats a fine idea till the transmission is laying from one end of the shop to the other and certain parts can't be had. Been there last year with a 4255I think the answer is you buy 7140 Magnums or 4960 Deere's, and keep rebuilding them as needed. Yes you may have to go back to driving them yourselves like the olden days prior to autosteer.
It would take an aftermarket ECM of some type, but it could be done. Not full mech though. But it is not that hard to make some sort of computer that reads engine speed and position and turns injectors off and on. The rest is profit for the manufacturer.
It will be done at some point in the future, to get us out from the boot of big government/big mfr. How much pain is involved until society gets us to that point remains to be seen.
The old system of, only approved parts from approved mfr worked OK so long as the approved parts were somewhat affordable, and were available. But to shut down hundreds of thousands of dollars worth of equipment over a few hundred dollars of silicon and some lines of code is not going to work for the long run.
And is the main reason for everything going electronic, as well as more work for dealer shops. Any other reason is based on lies.Unavailable?
How about an Allison 1000 TCM, or, better yet, a Duramax LLY FICM. Used are going for $3k UsD, as none new are available.
It won't be allowed, just like all the crack down on the tuner stuff. Read post above.I am thinking an electronics manufacturer could make a one size fits all ECM. Sell an adapter harness to connect to the OEM connector and then whatever connector they have chosen for their ECM for Cat, Deere, Cummins, whatever. Include the usual inputs and outputs on the base ECM and then sell an extra box as part of the adapter harness perhaps, to drive piezo injectors, unit injectors, whatever, if those require strange voltage or power requirements that you would not want to include in your base box.
Then just install and upload the correct software to run the engine you have. Just work off the regular inputs and outputs, temp, position, oil pressure, CAN, and the like.
I work with industrial controls right now that include all sorts of useless features we never use on the board because it is more efficient to produce just one product for all customers.
Analog control modules can likely be figured out and components on the boards replaced for repairs. Problem now is that ECMs are digitally operated which means that even if you figure out the failed components, the control programs are digital software and you still have to get the software from the manufacturer. As I said days ago when all this started, only the manufacturers of the engines can certify that any aftermarket component or software can be guaranteed to meet emissions regulations. Anyone can make a component to work. They just won't be able to get the manufacturer to take responsibility for it.
Like a PLC.I am thinking an electronics manufacturer could make a one size fits all ECM. Sell an adapter harness to connect to the OEM connector and then whatever connector they have chosen for their ECM for Cat, Deere, Cummins, whatever. Include the usual inputs and outputs on the base ECM and then sell an extra box as part of the adapter harness perhaps, to drive piezo injectors, unit injectors, whatever, if those require strange voltage or power requirements that you would not want to include in your base box.
