john_from_kingston
- Joined
- May 6, 2020
- Messages
- 5
I have a Deere 450C crawler loader and it has not run in years, so a new battery and it is running fine. Went to move it and the clutch pedal linkage doesn't seem to be doing anything... I have the YUGE JD shop manual and I searched for transmission clutch adjustment and there is a tiny crappy 'sketch' of the parts involved with the transmission clutch and foot pedal. Is the foot pedal supposed to rotate the pivot pin it is on, like with a set screw or something, or does the pedal just pivot on the pivot pin and the other linkage on it does the actuation? The pedal does not return to the up position, so I'm guessing the return spring is missing in action - guessing it is floating around inside the bellhousing? I have the floor plates up and trying to figure where to start on this? Does anyone have a picture of a properly adjusted foot pedal with linkage?
