mg2361
The short line stays there with the other line and the tee. That auxiliary combiner circuit does not get used unless two pump combined auxiliary flow is installed to run something like a shear.
The aux flow combiner cap and the one port on the selector valve both need to go to tank. What is happening is the normal leakage within the spool itself leaks into the cap area. Since the cap has no path to tank the pressure eventually builds in the cap and then it breaks. The cap is supposed to be plumbed to the DN port of the solenoid valve and the selector valve port pictured below is supposed to be plumbed to the DM port of the solenoid valve. You can, if it is easier, just tee into one of the tank ports and run both to that.
