Per Eriksson
Anyone have any experience with piston pump pressure pulsation dampening to reduce the noise and vibrations in the hydraulic system and machine?
The machine in question has a double axial piston pump, 2x400l/min and a max of 35000kpa
sound is worst around 1500rpm.
What I have gathered so far is that it can be done in basically 3 ways,
Bladder accumulator installed on the pressure line so the flow goes in and then out of the acc.
Not too big but have moving parts which could fail and end up messing the rest of the system up.
"silencer", like a big steeltube that the flow passes right through, no moving parts inside which I like but very bulky and difficult nearing impossible to fit 2 of them in the machine.
"Dead end" hose, short length of hose T eed onto the pressure line.
Very easy to fit, cheap and no moving parts.
I'm leaning towards the dead end hose since that is something I have seen on other machines atleast in the caterpillar lineup but how the hell does the calcuations for them work, is it trial and error until the right length and size is found?
Anyone messed with this?
